problem with HowieFarkes Ultrascenery accelerator
2»
  • Dr ForkDr Fork Posts: 42
    Everything but the Water Pack.
  • barbultbarbult Posts: 26,432
    The Water pack files should be under Environments/Landscapes/UltraScenery/Water. I have 15 subfolders there - one for each type of water. Do you have those?
    Yes, those 15 Water folders are there, but they do not show in the scene creator, only the base three water types.
    Maybe you should reinstall the Water Pack product from DIM, making sure that the installation folder is correctly set to the library where UltraScenery is installed. There may be resource files in the installation that you didn't get manually copied to the necessary place.
    What is the status on the accelerator now? Is it working?
    Yes, everything but the Water Pack.  I'll try a DIM install now...
    No; no change.
    Is this correct?: Environments/Landscapes/UltraScenery/Resources/Materials/USC water MAT - 01, 02, 03.  No more.
    Yes, that is all I have in there, and all 15 of my water options show up in the UltraScenery water tab.
    Aren't there 12 more MATs for the Water Pack versions?
    When you look inside each of the 15 water folders, does each one have an info.json, a preview.png and a thumb.png file?
    Yes:   Environments/Landscapes/UltraScenery/Water/(All 15) each with the three files.
    Check the UltraScenery Build tab lower right corner. What version does it show for the script and the accelerator?
    edited April 2021
    Script Version: 1.3.2.2
    Accelerator:  1.0.2.3   (But the "Splash" box of the accelerator says 1.3.)
    Post edited by Dr Fork on
    Those are the most recent versions. You could try closing Daz Studio and restarting it, in case that is necessary after you reinstalled the files.
    The only other thing I can think of right now is to look in the Daz Studio log file (Help/Troubleshooting/View Log File). Run UltraScenery, open the water tab, then close UltraScenery and look at the log file. Scroll to the end and see if there are any errors or warnings related to UltraScenery.
    Last few lines of Log File:   2021-04-22 23:02:42.232 rot_y: -51.1446
    2021-04-22 23:02:42.232 rot_y: 66.0356
    2021-04-22 23:02:42.232 rot_y: -81.4342
    2021-04-22 23:02:42.232 rot_y: 7.4715
    2021-04-22 23:02:42.232 rot_y: -24.9566
    2021-04-22 23:02:42.232 rot_y: -25.6459
    2021-04-22 23:02:42.232 rot_y: -43.2046
    2021-04-22 23:02:42.308 File loaded in 0 min 0.0 sec.
    2021-04-22 23:02:42.310 Loaded file: USC water MAT 03.duf
    2021-04-22 23:02:46.084 Script executed successfully: C:/Users/Public/Documents/My DAZ 3D Library/Environments/Landscapes/UltraScenery/UltraSceneCreator.dse
  • FishtalesFishtales Posts: 6,219
    Go into the Environment Tab in Studio and make sure the Ground is set to Auto and not Manual.
    I don't see anything suspicious there. Those rot_y lines are a known issue of some debug code being left in the released version. HowieFarkes will remove them in a future update. I get them, too. I don't know why the water pack isn't working for you. Let me ask the obvious question: you did try to scroll down the list of waters the see more than three, right?
    Huh? How does that affect the list of water choices available in the UltraScenery Water tab?
