G8F 8.1 using G8F geoshells
I thought I saw a solution for the problem of using G8f geoshells on G8.1 but I forgot to bookmark it can anyone help
    Put a G8F and a G8.1F both in the scene. Apply the geoshell to both. Then copy the Torso material of the G8 geoshell into the Body and Head materials of G8.1. Now it works and you can delete the G8 (and save the now 8.1 friendly one as a new name if you want so you don't have to do it again).
  • jedijuddjedijudd Posts: 606
    Thank you SickleYield
    Very welcome :)
  • SevrinSevrin Posts: 6,314
    Thanks for the tip.  I've a bunch of geoshell products like Vyktohria's Skinz, and was just trying to figure this out yesterday.  It would be nice if Daz could come up with a solution that didn't require waiting for another character to load, what with the Loyalty Penalty and all.
    Good info for when I move to 8.1, thanks
  • GlennFGlennF Posts: 143
    Maybe I'm just reading this wrong but I still can't make the geoshell work on G8.1F Head area
  • Copy the body material to the head area and set the UV to Base Female and not Base 8.1 Female.
    Thank You
    Now it works.
  • WestKravenWestKraven Posts: 142
    Thank you so much Sickleyield!
  • ekke2020ekke2020 Posts: 60
    edited June 2021
    Hello,
    I can't do it. I have an 8.0 female figure and an 8.1 female figure (both out of the box, without any additional materials).
    Both have the same geoshell (Wet skin geoshell). The 8.0 figure is okay, with the 8.1 figure the body and head are white.
    I choose the geoshell of the 8.0 figure. In the Surface area, I choose Surface/Torso and click "Copy selected surface(s)".
    After this I choose in the scene panel the geoshell of the 8.1 figure. In the surface aera I choose Body and Head - Paste to
    selected Surface(s). However, the areas remain white. I've tried the same via menu edit / copy selected surface(s) and
    edit / paste as well. No success.
    What am I doing wrong?
  • GhostofMacbethGhostofMacbeth Posts: 1,775
    Ekke2020, what version of DS are you on? Any time I see "8.1 is white" I go to version of DS first. Because it needs 4.15.
  • FenixPhoenixFenixPhoenix Posts: 3,246
    ekke2020 said:
    Hello,
    Ensure that the surfaces (Body and Head) use the same shader as the original Geoshell. So, if it's Iray, apply to those surfaces the Iray Uber Base Shader (which you can find in your content library > shader presets > iray > DAS Uber > "!Iray Uber Base"). Now you should be able to paste the torso surface from your G8 to your G8.1 Head and Torso Surfaces.
    FenixPhoenix said:
    ekke2020 said:
    Hello,
    Yes, it works - thank you very much.
    My pleasure, @ekke2020. :)
