Pretty Big Issue Just Popped Up For Me....
Dark45Dark45 Posts: 94
edited April 2021 in Daz Studio Discussion
I'm in need of some assistance. Tonight I was working on a few models, I closed out of Daz and headed to the daz store to pick up some HDRI's. I installed the HDRI's via Daz Central and loaded back into Daz. Loaded up my model and the lower jaw / chin looked like the first image you see attached :(. I tried other models that are based off the same reference due to thinking maybe I saved after I screwed something up by accident, but they all look like this. Any ideas?
Although it does double as a try not to laugh challenge since it looks so dang derpy :'(
The second image I attached is what the model is suppose to look like.
Post edited by Dark45 on
  • Richard HaseltineRichard Haseltine Posts: 108,522
    Is it just the teeth or is the lower jaw also displaced? Does the base character load OK? Have you tried reinstalling that?
  • Dark45Dark45 Posts: 94
    edited April 2021
    Thank you for your reply and your assistance. It seems to be the lower jaw, teeth, and tongue are all displaced. This is a full body morph designed off of Gen 8 and Gen 8 loads fine. I've tried reinstalling morphs to no avail so far.
    It seems the values have changed on them, as an example, "Jaw Lower Depth" is completely a different value than what I had it set at on all my models for some odd reason.
    Is this a custom morph or a store product? It sounds as if some ERC linking jaw adjustments to the morph are broken.
    Store purchased, yeah I couldn't figure it out. I went ahead and re-adjusted everything I could... took forever and I really liked the way it was but oh well. Thank you for the help and brainstorming though.
