Pretty Big Issue Just Popped Up For Me....
Dark45
I'm in need of some assistance. Tonight I was working on a few models, I closed out of Daz and headed to the daz store to pick up some HDRI's. I installed the HDRI's via Daz Central and loaded back into Daz. Loaded up my model and the lower jaw / chin looked like the first image you see attached :(. I tried other models that are based off the same reference due to thinking maybe I saved after I screwed something up by accident, but they all look like this. Any ideas?
Although it does double as a try not to laugh challenge since it looks so dang derpy :'(
The second image I attached is what the model is suppose to look like.
Post edited by Dark45 on
Is it just the teeth or is the lower jaw also displaced? Does the base character load OK? Have you tried reinstalling that?
Thank you for your reply and your assistance. It seems to be the lower jaw, teeth, and tongue are all displaced. This is a full body morph designed off of Gen 8 and Gen 8 loads fine. I've tried reinstalling morphs to no avail so far.
It seems the values have changed on them, as an example, "Jaw Lower Depth" is completely a different value than what I had it set at on all my models for some odd reason.
Is this a custom morph or a store product? It sounds as if some ERC linking jaw adjustments to the morph are broken.
Store purchased, yeah I couldn't figure it out. I went ahead and re-adjusted everything I could... took forever and I really liked the way it was but oh well. Thank you for the help and brainstorming though.
