Missing "Script Menu"
Why is my "Script" menu missing? How do I get it back? What I am missing is access to DAZ to Maya Bridge. I am using the lastes version DAZ 4.15 Pro. and Bridge 1.7.
  • Tim NTim N Posts: 193
    In the Content Library pane, navigate to the Scripts > Utilities folder. Now double click on "Update and Merge Menus".
    That should fix the problem.
  • Richard HaseltineRichard Haseltine Posts: 109,533
    That's an older version of the tool, I think. It now has a permanent place in the menu bar - Window>Workspace>Update and Merge Menus
    I did that. That didn't work. Nothing changed. This is puzzling.
    Sorry, I was addressing the location of the command and not your original query. The Scripts menu is added when you create a Cusom action (right-click on a file) or when a script creates it as part of installation -  it isn't there from the outset. Are you sure the bridge isn't in the File menu, I thought a recent update had moved them there from Scripts.
  • Never mind. The plugin uninstall re-install solved it.
  • for me that did not work :(  I am trying to get the scipts function back fo two days now nothing works... does any one have more solutions?
  • k kn
  • It doesnt work for me, srsly no one has an answer to this stupid bug?
