Hair Cap Error
Hello Guys,
I have this error - probably because I have a 104% scale on the figure. There are no sliders to adjust the hair cap and I am going nuts.
(the error is the lines that are created from the head cap not fitting the head properly; sadly there are no pose morphs like OOT has to adjust the cap)
Any help for a solution that works for all hairs? Any add on that I can buy to use it on any hair cap?
Thank you so much - this is so frustating and it drives my mad
Found a solution:
1. Add a smoothing mesh - keep standard low values
2. Unhide the scale property and increase as needed.
In my case a 0.5% increase in scale did the trick... I was lucky this time, usually the smoothing and scaling doesn't work so nice.
If anyone knows a universal hiar morph, I would love to hear of it.
Thank you
Change the "Instance Optimization" property. It doesn't matter to what; just go through them and it will probably go away. If that doesn't work, try turning the scalp's opacity down to 0% or, as you suggested, using a smoothing modifier.
What hair is this?
Thank you all,
I will try all the ideas. I like Hexagon and I know a little bit about it.
The hair is: MRL Amara Braids
