clothing . character converters and options?
MistaraMistara Posts: 38,675
edited April 2021 in The Commons
hi,  i perusing the clothing coverters.  sy, rssy,
what i'm looking for
is something that can batch convert the g3/g8 general rigged clothes
to g2 triax rigged.
anyone know if one the converters can batch convert?
thanks.
Post edited by Mistara on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,226
    I dearly want this for both Genesis 2 and 1 and if possible V4 and M4 but I don't think many others do sadly crying
    it may be simply too hard to do too, I know manually it is a fair bit of work
    I've found clothing converters to be largely disappointing.
    I own several and the percentage of clothing converted reasonably well is. Probably less than half.
    the ones I have tried do batch convert but not all items get converted or converted properly so you have to go back and attempt to do it over with different tools.
    of course with anything your mileage will vary.
    the decrackifier works pretty well.
    and i've  used the masculinisers, looks like those utilities are gone.  unless they just changed the name of it.
    the nice thing about the older clothes, it takes a lot less memory.  outfits these days ar mostly over 100mb
    I think Sickleyield's pants masculinizers are now in one of the bundles she sells on ShareCG for around $10.
  • kyoto kidkyoto kid Posts: 41,943
    ...yeah I found that out as well.  Really hit or miss  I've even tried doing one piece of a clothing set at a time and still no success. Picked up a number of G8 items I liked to convert to G3 and, very disappointed that so little of it works save for dForce.
    this looks interesting.  https://www.daz3d.com/character-converter-from-genesis-2-male-to-genesis-8-male-
    only cuz i want gianni 6 on g8.
    part of me is skeptical.  it converts the uv map and everything?
    without geografts or geo shells?
    i'm using carrara, geo stuffs wont work for me.
    thanks!
  • DripDrip Posts: 1,238
    thanks!
    No, it *only* converts the morphs that make Gianni. The UV is still the Genesis 8 UV, so original Gianni textures won't look right. I think there is some product somewhere to use G2 textures on G3/G8 by adding some geografts on the problematic areas, but not sure that would work on Gianni, as G2 (and G3) core characters notoriously used a special UV.
    thanks.  yeah, cant use geografts in carrara.
    is there a product that can convert dforce clothes to rigged?
    i see a sy utility says it adds bones to skirts.  cant tell if it'll do the trick?
