Getting V4 Hair To Stay In Place
Zach WilsonZach Wilson Posts: 92
edited April 2021 in Daz Studio Discussion
Ok I haven't used this program since about 2008-10 ish and then only for about one day. What do I need to do in order to get V4 Ranger hair to stay on her head when posing.
Second and unrelated question is there any way to get the V4 Ranger outfit onto any version of Genesis?
Post edited by Zach Wilson on
  • Richard HaseltineRichard Haseltine Posts: 108,591
    The hair needs to be aprented to the head in order to follow it, since it is a prop rather than a fitted figure. That should happen on load, but since it isn't you could try parenting it with Parent In Place off (right-click the hair>Change Parent, uncheck the Parent In Place box) - that should snap it it to the head's orientation, and maybe position, so that it is relatively easy to settle. You could also try just rloading the hair with Victoria 4 selected, if it might not have been the first time.
  • Thank you I made sure Victoria was selected first then applied the hair and now it works.
    Good. There are hairs which fail to parent on loading, even if the figure is selected, and I couldn't recall if this was one of them.
  • BejaymacBejaymac Posts: 1,952
    With HR2 Prop hair DS will auto-parent it to the selected figure's head bone, with CR2 figure hair you are relying on a line in the CR2 to read "conforming 1" for it to auto-attach itself to the figure.
