Extracting Body Parts
I would like to do some studies with only hands. Is it possible to extract just the hand, maybe a full arm from the figures in DAZ?
If so, how?
Thank you :)
If so, how?
Thank you :)
Hmm... Well, a simple way you could go about it is turning off all the other regions on the figure from the Scene tab, or even dialling off the figure's material zones. Another thing I'm sure you could do is selecting all the hand polys with the Geometry Editor Tool and deleting the rest of the unselected figure. If you have a modeling application like Hexagon, ZBrush, or even Blender, you can export the figure to them and work from there.
Thank you for that info. I need to DL and get Hex up and running.
However, I admit that I am a real rookie at this. How do I turn off the other regions from the Scene Tab?
Ah, found it. Thank you very much :)
No problem! :)
