Any stereo 3d camera plugin?
I want to create a stereo 3d video by DAZ Studio, however any plugin for that?
If no, If I want to create left and right camera, any suggestion to get 3d effect?
Many thanks
Many thanks
For 3D, you can create two cameras. Make one a parent of the other. Make the child camera be 6.4 cm away from the other one in the X direction. The parent is left. The child camera is right. If you're using iRay, you can render half-SBS by setting the camera's X scale on the parent to 200%. Render both cameras and then you'll have to use some third party program to put the left and right frames together again. There are different ways to do this. You can create a video for each eye and then combined them with avisynth for example. Or you could download any of the free video editing software available and create two image sequences and display them in the appropriate place in the frame. ImageMagick can be used to merge images together before you create the video if you want to go that route.
There are probably other ways of going about it.
https://forum.videohelp.com/threads/336083-Combine-2-Videos-Side-by-Side
https://stackoverflow.com/questions/20737061/merge-images-side-by-sidehorizontally
I know it's the obsolete topic, but in case someoune would come here searching (just like me just a few minutes ago), here is a related product: MARSA Anaglyph3D | Daz 3D
