Trouble installing Fluidos II
I just downloaded Fluidos II, but the installation manual that came with it is less than helpful and there are many different files and folders. I don't know what to put where to install this properly, can anyone help me? I'll link a picture with the files that came with the download.
  • AlbertoAlberto Posts: 1,461
    Hi!
    You can install them with DIM or Daz Central. But if you prefer to do it manually:
    Inside the IM00064599-01_FLUIDOSIIforDazStudioStudioContent.zip and IM00064599-03_FLUIDOSIIforDazStudioTutorials.zip you will see a "content" folder. Uncompress the zips and copy the content of "content" folder to your Daz library (merge the folders).
    Inside the IM00064599-02_FLUIDOSIIforDAZStudioWin64bit.zip file you'll see three folders: DAZ Studio_4.5;4.x Public Build;4.x Private Build_(64-Bit), DAZ Studio_4.5;4.x Public Build;4.x Private Build and Temp_(64-Bit).
    If you have the last version of Daz Studio 4.14 or later, ignore the content of Temp_(64-Bit) . If not, decompress and run the .bat file.
    Localize the "DazStudio4" subfolder of Daz Studio installation. Normally, it's inside of "C:/Program Files/DAZ 3D/" (C: or the disk where you installed it). Copy the content of the folders DAZ Studio_4.5;4.x Public Build;4.x Private Build_(64-Bit), DAZ Studio_4.5;4.x Public Build;4.x Private Build to the "DazStudio4" subfolder (merge the folders).
    Finally, register the plugin using your serial number (https://www.daz3d.com/forums/discussion/comment/3916516/#Comment_3916516)
