Sharing my Extensions folder setup
RuudLRuudL Posts: 227
edited April 2021 in Carrara Discussion
On page 5 of the SDK Overview document it says:
When the 3D Shell is launched, it first identifies which 3D Components are available. To do this, it looks in its Extensions directory and in all sub-directories of the Extensions directory. All files with the '.mcx' extension are considered as Components.
The part in bold makes it possibly to organise the plug-ins. I've organised it so that each plug-in is placed in a folder that bares the name of its developer. And then all those developer folders are placed in a folder called '3rdParty'
My Extensions folder setup:
Pros and cons
+ After this setup is implemented correctly, you can always retrieve the name of the plug-in developer from its folder name.
+ Whenever you suspect a plug-in of causing problems, you can simply move ( not copy ) the '3rdParty' folder to disable them all. Or move one of its subfolders to disable only the plug-ins of a specific developer. And so on...
- It is possible to have multiple copies of the same plug-in in different folders. That might be confusing. But tests show that the Component-server will replace the registry entry of a previous copy with the last found copy.
Important
The pathnames of the ".key" files and of the "PyCarrara.py" file are hard-coded in the source of the plug-ins. It's best not to move them.
As a general rule:
Only move plug-in files with file-extensions of ".dat", ".mcx" and ".txt" and keep them together on a plug-in name basis.
I hope you find it useful.
Post edited by RuudL on
  • StezzaStezza Posts: 8,901
    great tips to organise your stuff thanks yes
  • Sci Fi FunkSci Fi Funk Posts: 1,198
    Good idea!
  • chickenmanchickenman Posts: 1,202
    Mine is organized simularly, with extensions then Extenstion name.
    example
    Extensions --- Anything Glows
                      --- Advanced Shader Weaker
    you get the idea.
    It just makes it easier to add and remove them if you need to.
    kewl.  thanks.
