Dripping Blood ???
Brotherlobo
Okay, question time.
Any good products out there to add blood dripping off the blade of a weapon while still in DAZ?
NOTE: I primarily work with the G1 and G2 figures.
Of course, there is always the possibility of adding it in with Photoshop. Any recommendations here also?
Thanks in advance.
What about this one?
http://www.daz3d.com/rons-blood
These are Photoshop layers, so you need either Photoshop or a 2D software that can open PSD files.
You might also be able to use http://www.daz3d.com/rigged-water . Whatever you do is going to require considerable user-adjustment since DS doesn't have a fluid simulation system.
Not specifically for swords ... there are these packs.
http://www.daz3d.com/add-on-for-zombie
http://www.daz3d.com/subsurface-goop-shaders
http://www.daz3d.com/liquid-pack
You'll have to import and apply a material (easy), but Spacebones' liquid has some drippy stuff:
http://www.sharecg.com/v/25522/view/5/3D-Model
Thanks for all the suggestions. I will give some of these a try.
