mcjSelectAllMyChildren: DS 1- 4 Script selects all sub-nodes of selected nodes
mCasualmCasual Posts: 4,607
edited November 2015 in Freebies
Save a second of work here save a second of work there and soon you saved 2 seconds of work.
so, you want to make the AmyWagen prop invisible, and you select the root node, turn off visibiliity and ......... the 50 sub-props are still visible !
but now with mcjselectallmychildren
select the root node, run the script
Bam, all 50 sub-props selected
turn off visibility in 1 click
Also very practical for fingers animation
Dowbload here ----------------> https://sites.google.com/site/mcasualsdazscripts4/mcjselectallmychildren
in fact the code is so simple i'll post it here
for edumational purposes
"is our children learning?"
var roots = Scene.getSelectedNodeList();var n = roots.length;for( var i = 0; i < n; i++ ){ selectChildren( roots[ i ] )} function selectChildren( root ){  var children = root.getNodeChildren( true ); //recurse  var n = children.length; for( var i = 0; i < n; i++ ) {  var node = children[ i ];  node.select( true ); }}
    Thanks Casual, your scripts are always useful.
    I might even have a look at how it works :)
  • selias19selias19 Posts: 254
    Many thanks for this, Casual.
    Again one of those "Must Have" from you.
    I use your "Come Here" script all the time.
    Sigrid
  • MorganRLewisMorganRLewis Posts: 233
    One of those ideas that's brilliant in its simplicity. Thank you!
  • DorseylandDorseyland Posts: 724
    Finally, a script I can understand. Thanks, Cazh!
  • RAMWolffRAMWolff Posts: 10,369
    So this will work on say Genesis and all the body parts too? If so that would be so awesome. It's such a pain to run through turning off all the fingers .. YUK!
    Thanks so much Casual!
  • mCasualmCasual Posts: 4,607
    yest though in DS 4.5 you have to be careful not to select the root node when you select the body part
    here i selected the foreArm and the script selected the hand and fingers
    605 x 605 - 62K
    OK, that's very good. Thanks so much!
  • HellKoreaHellKorea Posts: 17
    Thanks casual..
    but daz has already this function.
    so i change some code to hide toggle from select.
    it's very convenient to me. :D
    roots.setVisible(!roots.isVisible());
    selectChildren( roots )
    var node = children;
    node.setVisible(!node.isVisible());
    400 x 338 - 68K
