Is there a way to list the difference in morph settings between two figures?
background
in The Commons
I have been working on a character and over several versions I have adjusted a lot of morphs ( some bought, some I made myself ). It would be useful to compare the morphs used and their settings between particular versions, so what I need to do is list only the differences, and ignore the settings that are the same in each. Does anyone know of a way to do this?
Well, ytou can see which are different if you select both and scroll through the morph list - any that have different values between the two will show <?> as their value. Proeprties thata re on both figues will have (2) after their label, so if there isn't a (2) it's a proeprty that is one only one of them
Thanks very much Richard, that's really useful, at least now I can make a list of which morphs are different between the two characters and then go back and check the actual values for any with a <?>.
