Looking to buy medieval dforce long shirt - see images
jonrowlison
I'm hoping to use DazStudio to animate a few character intros and book cover for an upcoming work. I'm looking for an existing long shirt that people may be aware of or creation of a custom item. I would have been able to do this myself in the very early Daz/Poser7 days, but it's been a long time and I haven't kept up on that skillset into the dforce age. Any takers and an estimate on what this would run me? The hood and/or hand coverings on the first image aren't a requirement, but I'd take them if they exist.
https://www.daz3d.com/dforce-hooded-outfit-for-genesis-8-females
https://www.daz3d.com/dforce-elf-guardian-outfit-for-genesis-8-female
https://www.daz3d.com/dforce-night-intruder-outfit-and-poses-for-genesis-8-females
https://www.daz3d.com/dforce-cirth-outfit-for-genesis-8-females
https://www.daz3d.com/dforce-cerian-nobility-outfit-for-genesis-8-females
EDIT:
Didn't read the title all that close, so I removed the non-dForce items.
Some of those are kind of close. The two outfits need to be a little more specific. Because I'm not doing a lot of motion, I could probably drop the requirement that they be dforce clothes... but it's long shirts (or very short dresses) with pants underneath that I'm looking for. Specifically, I'm needing the vneck shirt with front laces and then a higher square neck.
There are some good suggestions already. You might also want to have a look at the Divergence outfit at Renderosity.
You may end up having to cobble your outfit together from separate parts like a lot of folks do, i.e., the hood from one outfit, tunic, pants, boots, belts from others, and bring the look together by using shaders.
The suggestions above are all great pieces. In the end I didn't find anything "close enough" to what I needed. I have a passing skill with Marvelous Designer and was pretty good with Poser Cloth back in the day... I'll take a crack at designing what I want myself and if anyone is interested, I can post some snapshots. They'll be partially-conforming dForce cloth long shirts for G8F.
One of the shirts has will have a laced neckline. Does anyone know if Daz has a way to make the laced section into a morph target? So that if you choose the "Top-unlaced" morph, you can tell Daz to include the top flaps in the simulation instead of conforming them to the figure?
