Help, my mouse button 4 & 5 can not be used
my new mouse has button 4&5 on left side, which can be setted up in Blender for Orbit and Pan, but when I tried to set it up in DAZ, the software does not recognize these buttons, how to do?
  • Richard HaseltineRichard Haseltine Posts: 108,650
    You'd need to assign them to keyboard shortcuts for teh commands you want to use - I don't know if they can be made to emulate another mouse button plus a modifier, which is what you need for Viewport navigation.
  • SevrinSevrin Posts: 6,313
    I have a Logitech Proteus with a bunch'o'programmable buttons.  You can assign simple mouse clicks, or double-clicks, or keystrokes, or combinations and sequences of keystrokes to buttons, but you can't combine keystrokes and mouse-clicks.  Like you can make a macro that, when you click on a slider in DS it resets the value to zero, but you have to click it first.  The fanciest you can get with mouse functions is setting a hotkey to zoom in or out as if you were Ctrl-scrolling.  Can't do it with my Razer, either, last I checked.
  • ioonrxoonioonrxoon Posts: 896
    The only way I found to do this is to use Autohotkey. This is the script I'm using to change orbit to side button:
    *XButton1::
    SetMouseDelay -1
    Send {Blind}{Alt Down}{Ctrl Down}{LButton Down}
    return
    *XButton1 up::
    SetMouseDelay -1
    Send {Blind}{Alt Up}{Ctrl Up}{LButton Up}
    return
    To use it, alter the keys with whatever you want (use it twice and replace XButton1 with XButton2 for the second side button), save it in a text file with .ahk extension and run it after installing autohotkey.
  • McGyverMcGyver Posts: 7,085
    None of the buttons on my mouse seem to work...
    And yes, it was totally worth the eight minutes it took to find everything to make that picture.
  • Phoenix1966Phoenix1966 Posts: 1,865
    Yes, yes it was worth it.
