How do you get M4 Creature Creator to load the morphs?
Hi,
I recently purchased the M4 Creature Creator Bundle. I downloaded and installed through the Daz Install Manager. I can see the morph faces in my content library and saw that the checkboxes for "INJ Creature M4" were all checked when I loaded the Michael 4 base model. Yet when I double click the morph faces nothing happens to the model, nor does anything happen when I drag the morph face onto Michael and tell it to "fit to Michael 4". I've had no problem using the creature creator for Genesis and am wondering why these morphs won't load. They also don't show up in the sidebar like the Genesis creature creator morphs do (please see attached jpg).
Any help would be greatly appreciated.
Thanks.
  • fixmypcmikefixmypcmike Posts: 19,709
    Those icons are for injecting the morphs into M4 -- you then need to go to the Parameters pane and dial the morph to the desired strength.
    (If you get the Powerloader window when you load M4, you don't need to inject the morphs manually, BTW.)
