Starion's WIP and test thread
1161719212228
  • starionwolfstarionwolf Posts: 3,670
    Skimpy outfit - Andromeda
    800 x 600 - 135K
    I haven't uploaded a good render of Sexy Maid Outfit for Genesis 2 Female(s).
    501 x 576 - 106K
    663 x 576 - 123K
    edited August 2014
    Playing with lights and shadows. I like how the scene is dark.
    Memory usage: ~ 575 MB.
    501 x 576 - 102K
    Post edited by starionwolf on
    Lana is on the left and Gwen is on the right.
    774 x 592 - 96K
    Thank you for not complaining about how inappropriate my renders are.
    Techno Tabby and Helena skin on Victoria 4
    501 x 576 - 116K
  • mori_mannmori_mann Posts: 1,152
    Compared to some stuff popping up in my renders, this is not all that inappropriate, really ;)
    Hi mori_mann, thanks for looking. Here is classic deco in bad light. Opps.
    Memory usage: 1.8 GB.
    800 x 600 - 137K
    edited August 2014
    Take a look at this render while I try to fix my current issue with Victoria 4. I did not add any walls because I am using 32 bit Daz Studio.
    The shorts of Victoria's pirate outfit are cut low.
    Memory use: ~1 GB
    936 x 576 - 163K
    edited August 2014
    Fantasy Assasin's Creed
    Playing with an old scene. This scene would be more dramatic if I adjusted the lighting or changed the background. :D Yes, Victoria's armor is supposed to be white. I'll apply a shader to it later.
    874 x 576 - 161K
    The background is a bit too dark.
    800 x 600 - 79K
    Skimpy outfits by Val3dart will follow
    Arkangel
    Memory usage: ~850 MB
    518 x 576 - 87K
    I should change the name of the thread to my skimpy outfit test thread. lol
    Arkangel uses less memory than I expected. It uses 685 MB. Now to find out how much memory Luke uses.
    518 x 576 - 115K
  • NovicaNovica Posts: 23,924
    What is that black rounded, semi-transparent shadow on the render where you mention her outfit is white? On the left side.
    I like the action in these, you can really feel the energy.
    After I adjusted the lights, the shadow still exists. The light isn't fully illuminating the curved surface of the background mesh and texture.
    Bed time. I forgot to load the teddy bear.
    518 x 576 - 83K
    Fun with 64 bit Daz Studio. Yes, I know the scene needs work.
    Memory usage: 1.1 GB. 1.4 GB while rendering.
    800 x 600 - 117K
    Catgirl taking a shower. I'll try to fix the lighting.
    508 x 576 - 97K
    Cat lady and Luke switch places. I want the spray tool. Too bad I missed Nerd3D's sale.
    518 x 576 - 110K
    Ah, I see! I haven't had that happen...yet. I'm sure I will! :)
    edited September 2014
    Psycchotic. My attempt to recreate the shower scene from Alfred Hitchcock's movie Psycho. Its a start. I forgot to apply the texture to fantasy assassin.
    Image removed, please refer to http://www.daz3d.com/forums/discussion/3279_98/ Thanks for your understanding :)
    Post edited by DAZ_ann0314 on
    I remembered that I have Major Cache For Michael 4. I tried to render a better version but 32 bit Daz Studio ran out of memory. Looks like I will need to re-create the scene on the Windows 7 computer.
    518 x 576 - 94K
    edited August 2014
    Here is another scene that I need to setup on the 64 bit Windows computer. I didn't even load a background yet. Wilde Rhoads for Genesis.
    I think the guns have a lot of polygons? I'll try loading the clothes without the guns and holster.
    521 x 576 - 106K
    edited August 2014
    I finally made a decent render. Opps... you can't see her face. Let me fix that.
    Memory usage: ~710 the last time I checked
    Edit: here is the new version.
    518 x 576 - 99K
    edited August 2014
    64 bit version
    Daz Studio uses 750 MB of RAM when the scene is loaded but when Daz Studio is idle.
    Daz Studio uses 1024 MB of memory when it was rendering the image.
    800 x 600 - 123K
    Elven Nymph. I'm too sleepy to create a more fancy render on the fast computer.
    800 x 600 - 190K
    reminder for me to work on some old, romantic renders
    800 x 600 - 145K
    quick test render of Stephanie Petite 3. I thought have already created this scene. Apparently, I did not. Therefore, I had to create this scene. I'll play with the lights some more.
    518 x 576 - 82K
    Dawn and Stephanie Petite. I would have rendered the scene in Lux render but I ran out of time. At least I saved the scene file so that I can setup the scene using Luxus or Reality.
    727 x 594 - 133K
    quick test render in Luxus
    699 x 593 - 119K
    Wachiwi. I forgot to load her hair. I loaded Hawthorn hair instead.
    518 x 576 - 84K
    GIS Pro again. I know, the lighting needs work.
    800 x 600 - 216K
    800 x 600 - 234K
