37597 Turkish Bath : Pillar issue [Solved]
Noah LGPNoah LGP Posts: 2,617
Hi,
There is something wrong with the pillar prop.
Post edited by Noah LGP on
  • Richard HaseltineRichard Haseltine Posts: 109,000
    Did you get an error? Have you checked the log (Help>Troubleshooting>View Log File and scroll to the end just after loading the prop)?
  • Noah LGPNoah LGP Posts: 2,617
    edited March 2021
    2021-03-28 11:47:25.198 	Json Parser (601514,28): Syntax Error - expected ',' or ']'2021-03-28 11:47:25.452 	Json Parser (601514,28): Syntax Error - expected ',' or ']'2021-03-28 11:47:26.120 	Json Parser (601514,28): Syntax Error - expected ',' or ']'2021-03-28 11:47:26.366 	Json Parser (601514,28): Syntax Error - expected ',' or ']'2021-03-28 11:47:26.394 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(2190): Could not find geometry definition: /data/PerspectX/Turkish%20Bath/Pillars/Pillar.dsf#geometry.2021-03-28 11:47:26.394 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5727): Could not find geometry for the material instance.m_uri.2021-03-28 11:47:26.397 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1602): Failed to create material!2021-03-28 11:47:26.397 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5727): Could not find geometry for the material instance.m_uri.2021-03-28 11:47:26.397 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1602): Failed to create material!
    7-zip can't unzip Pillar.dsf and Pillars.dsf , errors occur.
    edited March 2021
    Thank you Richard for your help !
    I uninstall and reinstall this product, it works now !
  • NorthOf45NorthOf45 Posts: 5,733
    Wait until you add people, and don't look out the windows.
