So I need to download DAZ Studio with Genesis & Dson Importer just to get Genesis 2 female into Pose
What is the simplest way to get a genesis 2 female into Poser with the least amount of hassle?
Do I have to learn how to use DAZ Studio just to get Genesis 2 female or Victoria 6 into Poser via the DSON Importer?
Just forget about it, it's too much work.
Are there any new Victoria models coming out without having to use DAZ, genesis or Dson?
Post edited by HenryChan2 on
There is documentation about using the DSON Importer with Poser here
http://docs.daz3d.com/doku.php/public/software/dson_importer/start
The DSON importer is designed to be used without the need for a DS installation.
As the content for DS has separate installers (just like any other item in the shop), you can "buy" DS for free (DSON is free too if I'm right) and install Gen2F only.
The DSON importer download actually includes the Genesis starter essentials
The DSON installer will show a screen during the installation process. It will ask you if you wish to install the DAZ Studio 4.x files. If you do not have DS 4.5 or higher installed on your system make sure the box is checked. It will install the necessary DS files to your system along with the Python scripts needed by Poser.
Make sure you install both the Genesis 2 Female Essentials and the Poser Companion files to the same runtime.
Thanks for the help, I also used this video to help with the install.
https://www.youtube.com/watch?v=a7B2VZRrc_E
