I cant understand a step in this tutorial
halfmast88halfmast88 Posts: 63
Im trying to follow a tutorial on how to make custom faces for Daz models using Daz studio/Hex/and photoshop (Gimp in my case). I Should probably just quit now because I'm only on step 3 and it make no sense to me whatsoever. Here is an excerpt from the tutorial. The whole thing can be found on deviant art here: http://deslea.deviantart.com/art/Tutorial-Lookalike-Faces-in-Daz3D-and-Hexagon-426158536.
Step 3: Set Up Your Workspace
Your workspace consists of: Daz on one half of your screen with your base figure loaded, your browser on the other
open to your full-frontal picture, and Photoshop open in the background. Use your Default Camera and zoom and
angle on your base figure so that the view is a very close match for your reference image (this much I understand).
Take a screenshot of your workspace and paste it into a new document in Photoshop. Paste another copy of the
screenshot, make it semi-transparent(1), layer the figure over the photo to check your angle, and correct your zoom
and angle on your base figure if necessary (2). You want the head lengths to exactly match, because this grounds your
other measurements. (ie, the head length is the same on your figure view and your picture).
1. If i have a picture why am i screencapping anything? I made a semi transparent image in Gimp by selecting the photo from the layers pane and sliding the opacity down to about 50%, flattened the image and then saved it.
2. I now have a semi transparent photo, but the back of gimp isn't transparent and cant be successfully layered over anything. Do i somehow open it as a template in daz? is there some way to make the whole of gimp transparent? Am I missing something completely? Whats going on? I would normally google a problem like this but there isn't even enough information to know what to google.
Can someone kindly list the steps containing enough information for me to figure out? I have included an equally unhelpful photo from the tutorial, but maybe someone else can make some sense of it? Thanks in advance
