Adding to Cart…
When a man and a goblin love each other very much..
...they exchange loving glances!
Then the goblin steals his heart (and eats it).
Though, often the dangly bits don't even work with some clothing (even the ladies ones have trouble) and poke out..
You could also use a primitive scaled around and parented to the area probably (which might even cause less problems).
A simple "bulge" morph often gives better results than trying to use clothes with the geograft.
It is indeed compatible with Genesis 8. It uses the same UVs Genesis 8 uses, so any skin used on Genesis 8 will technically work on him. Only thing that has changed is the shader which is the new PBR shader, otherwise should work just fine on Genesis 8 with exclusion of the Expressions which are specifically multiplied for use with 8.1 Expressions and the FACS system.
Hope that helps for those who are on the fence about picking it up.
Uhm... could it give some more detail, pls?
Thanks, if You find the time to answer to this
1. Yes
2. Yes
3. Yes
4. Yes, they should. They might have to use the PBR materials
I am pretty sure about all of these answers but not 100%. They should be the same as other characters but I know there has been some confusion along the way.
There is no way to load the morphs on to G8, they won't show up in the parameter dials so there is no way to load them that I can see.
There are a couple male leather thongs that look bulgy. I don't remember off the top of my head but one mightbe from the Frog guy's loin cloth. Just need to make the fronds invisible.
Inside the installation file, are the morphs located in G8M or G8.1M morph folders?
File List [Documentation Center] (daz3d.com)
The file list shows /data/Daz 3D/Genesis 8/Male 8_1/Morphs
In that case G8M doesn't see the morphs, ie. they are meant exclusively for G8.1M, but...
I can see two ways to get G8 to see those G8.1 morphs.
1. Copy or move the morphs manually to G8 morph folders, although copying may not be a good idea with DS 4.15 as G8.1 would see the morphs twice afterwards, may also require some manual editing to fix the paths.
2. They have introduced a new folder with the G8.1 "...\Data\DAZ 3D\Genesis 8\[Gender] 8_1\Add-ons\Daz 3D\Base\", which contains a file "DazAddonPath.dsf".
Inside this file they are telling DS 4.15 which folders to read to add the G8 morphs to the figure.
If you added the same folder stucture to G8 and made G8 it's own "DazAddonPath.dsf" which told G8 to read the G8.1 morph folders, in theory you could get G8 to read G8.1 morphs but I have not tried this (yet)
