Genesis 1 base figure problem
Daniel BarnettDaniel Barnett Posts: 389
When I load Genesis figure it doesn't look right. It has thick thighs and large & pointed breasts.
This is what appears in my log when I load the figure -
Loaded file: Genesis.duf
Loaded Morph Deltas in 0 min 0.0 sec.
Loaded file: GENESIS WARRIOR PRINCESS.dsf
Loaded file: V5.1.dsf
Ran tdlmake on image P:/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHeadM.jpg
WARNING: QAccessibleWidget::rect: This implementation does not support subelements! (ID 2 unknown for QWidget)
Ran tdlmake on image P:/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeLimbsS.jpg
Ran tdlmake on image P:/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHeadB.jpg
Ran tdlmake on image P:/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHeadS.jpg
Thanks!!
dbb
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,524
    you must have saved her over your original genesis
    remove and reinstall warrior princess with DIM
    and reinstall starter essentials
    if that does not fix go to My Library\Data\DAZ 3D\Genesis\Base\Morphs and find her dsf and delete it before reinstalling use search
  • Daniel BarnettDaniel Barnett Posts: 389
    Thanks!! I'll give that a try.
    dbb
  • Richard HaseltineRichard Haseltine Posts: 109,290
    The Warrior Princess was set up incorrectly, so that it loads set to 1. The simplest fix is to uninstall it, but if you want to keep it you should be able to find the morph in the Parameters pane, click the gear icon on the slider and then choose Parameter Settings, and change the default and current values; then go to File>Save as>Support Assets>Save Modified Assets, make sure only the morph is checked in the dialogue, and click Accept. Reloading Genesis should then work correctly, I think.
    I'm not able to find her anywhere including in DIM or any data files/folders. I'll need to close for now and try this in the morning!!
    Thank you so much for your reply!!!
    dbb
  • Scott LivingstonScott Livingston Posts: 4,348
    Both Warrior Princess and V5.1 (also noticed that listed in the log) have this issue. Both of them are freebies from another site, so they wouldn't be in DIM.
    sorry was not familiar with warrior princess I had it happen with Stephanie curvy which is DIM fixable.
  • BejaymacBejaymac Posts: 1,966
    Didn't know those two disasters were still available, I thought ShareCG removed them a long time ago.
    edited August 2014
    Never mind I found the artist - Marcius Hess is the folder but this is not in my main Library in Studio. I did find it in two external runtimes that I have mapped. Does anyone know if this is why it is showing up and if I that these external Libraries/runtimes if that will fix Genesis???
    I must have them stored and reinstalled at some point. Do you know which artist provided these files? I can't find them anywhere except when I load Genesis in studio and then they show up with Genesis in the scene. This is really driving me crazy!!! The DSF's cannot be located!! Any more help would be appreciated!!!!
    dbb
    Post edited by Daniel Barnett on
    Yes, if they're installed and mapped that's probably the source of the problem. You can find some more information here: http://www.daz3d.com/forums/discussion/10820/#154445
