Toyen Cute Braids -- Does it have to be cartoonish in the viewport?
Hi, recently have been using Toyen "Cute Braids"  and another Toyen hair item. In the viewport, whatever material I apply, that color appears sort of flat and uniform -- so it looks cartoonish compared to the Genesis 8 female wearing it. In render the hair of course gets more realistic, but I wonder if there is anything one can do to make the hair look in the viewport more real and less like a cartoon?
Thanks for any suggestions.
  • margravemargrave Posts: 1,822
    edited March 2021
    I wouldn't if I were you.
    Strand-based hair relies on what're called "guide hairs" to control the overall shape of the hairdo. When you render, the software interpolates all the hairs between the guide hairs.
    However, if you tried to display all those interpolated hairs live, simply trying to pan the viewport would probably make your computer grind to a halt and then explode due to how processor-intensive it is.
    Post edited by margrave on
  • So what I am seeing in the viewport -- that sort of cartoon hair -- those are guide hairs?
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,260
    edited March 2021
    some strandbased hairs you don't even see that much
    unless you are planning on using viewport renders for your final work honestly what does it matter!
    Yes.
  • Okay.
    Sometimes I don't want to render, takes a long time, and prefer to quickly use a viewport image.
    I guess this means avoiding strand based if I want to rely on the viewport that way in future...
    edited March 2021
    Okay.
    You might want to look into fibermesh hair. Fibermesh is basically the same thing as strand-based, except it puts all the strands on display at once. It looks as pretty as a picture in the viewport. It'll also turn your viewport into a picture. We're talking a single digit framerate.
    For the above reason, typically it's only used for very short hair such as this: https://www.daz3d.com/classic-side-part-hair-for-genesis-3-and-8
    That PA, RedzStudio, makes a lot of good fibermesh hair, though if you notice when it comes to longer hair they switch to strand-based as well.
  • margrave and WendyLuvsCatz, many thanks
    yeah as I use Filament a lot I have been seeking out all the Fibermesh hairs ( and making my own in Zbrush)
    because that engine hates opacity maps but is excellent with mesh
