NEW 2021 Sales thread: Report Issues Here "There's Always Another Sale™"
Adding to Cart…
There is about 2 more hours until DAZ noon. I am waiting until then to determine whether or not I can use it on the items I want or whether I return the bundle.
I didn't even receive the coupon for purchasing the bundle yesterday. It's not in my messages, my email and I don't heve a store credit. I am going to put in a ticket but this is beyond annoying
You probably should wait a couple of hours more before submitting a ticket. See Richard's and my posts above.
Thanks Charlie...I must need more coffee. I didn't mean to double post. I didn't realize I posted the earlier message. I thought I deleted it while I double-checked something...and I must have pressed enter.
Well, If I promote a coupon and do not specify any restrictions it is fair to assume that there aren't any, no? - It would have been perfectly fine if they had done some disclaimer that the selection of items may be restricted, that no new releases or PC+ items would be covered etc. But it is IMO not OK to limit this afterwards.
As you're well within the refund period, you could apply for a refund of the purchase of the original? If you do, make sure you explain why.
7 minutes 'til noon (Daz time), and I don't have my coupon either.
EDIT: Got it
Message about the coupon is back, but the code is not working.
My coupon isn't working either.
The same for me.
The coupon is not working for me either.
I give up. And anway it says it excludes the items I had originally planned to get with it (new). I'm fed up; so I guess I'll just ask for a refund of the Vizier Bundle
ETA: Refund request now submitted !!!
Not working for me as well
Not working here either. No disclaimers on either yesterday's promotion or the orange coupon offer.
Same here: "Coupon Code is not valid". And I selected only items from the link in the Message.
If there is someone who is responsible for quality control at DAZ - in the Company where I work he will get fired!
Reported the coupon issue.
So, the coupon that has been withdrawn because it did not work as expected is now back, just to not work at all? Great move, really.
Coupon still doesn't work...This is silly
Like Joe 2018, I selected items only from the link with the coupon message. The coupon gave a "Coupon not valid" error.
This is being investigated.
Coupon now works, but same as in the morning: not deducting the full $20.
Same here.
Coupon worked for me, full $20 came off.
Amount should be right now, it was just given a little tweak.
It was deducting the full $20, but other discounts are applying after the $20 was taken off of their totals.
So if a product was $40, and we deducted $20 and then took 50% off it would end up with a total of $10.
But if product was the same $40 and the 50% off came first, and then the $20, you would get a total of $0.
That's why you generally just see % discounts, because it doesn't matter if you take 50% off and then 20% off, or 20% off and then 50%, the order of operations doesn't matter so it always works out correctly. The old store seemed to always do dollar subtractions before the percentage subtractions so that is why it used to try to apply parts of the PC+ coupons to free items, the new store allows the administrator to set the order that the discounts are taken so we can adjust that sort of math.
FIXED - I repeated the cart with the same items and the coupon worked this time. No "invalid coupon" error.
Thank you for getting it all worked out.
It worked for me. Thanks guys!
Worked
Thanks, Richard, and thanks for the explanation, Rawb. It now worked as it was supposed to. :)
It doesn't work for me. Before applying the coupon, I have 4 DO products for less than 20$ In my cart, with other products. After applying the coupon, I have a total balance of 4,93$ to pay for the 4 DO products.
Is anyone else having problems with recent purchases where after installation via DIM the icon under smart content don't display and all you are seeing is an exclamation sign? This is happening to me with the products in the two recent bundles for Cleopatra and Royal Vizier, it just started happening since the release of those two bundles.
