Changing Loose clothing to Skintight
There is any way to make an existing full body "loose" suit become skintight? I want to change a full body suit to a skintight costume, like Genesis Supersuit. Using Daz 4.6.
Thanks in advance.
Thanks in advance.
Yes import the obj and use autofit
If its a ds file. Export it as an obj first then do autofit.
Thanks for the quick answer.
How I can use autofit in an obj? I know only how to use it on a figure.
Edit convert to figure the three little lines in the corner of the scene tab with the obj selected.
Thanks with the help.
The upper part of the costume is great, but the the legs and boots don't fit to the figure. Any idea how to fix it?
Thanks again.
The suit is a M4 bodysuit and I'm trying to use it with G2M.
The image shows what happened when I followed ssweete's tips. The upper part is just perfect and tighter than the original, but bellow the knees the costume isn't even fitted.
May anyone help?
First you would have to make it "for" G2M. There are some conversion utilities in the store.
edit to add links:
Free tutorial here: http://www.daz3d.com/using-auto-fit-michael-4-to-genesis-2-male
http://www.daz3d.com/basicwear-for-m4 free atm too
http://www.daz3d.com/michael-4-for-genesis-2-male
Thanks, Patience55,
The only conversion utility for fitting I found it's for use G2F clothing with G2M, my you, please, give me an example?
EDIT: I have the M4 to G2M tool, and it converts the suit just right, but I wanted to make it more skintight than the original version, so I tried to use the obj without morphs.
I think our posts crossed ... I added links in my post above.
Fit it to Genesis and then unparent it and fit it to G2M as a Genesis item. It works most of the time.
It worked.
Thanks for helping me.
