Iray and Nvidia GTX 770
Hello, I have two Nvidia GTX 770 installed and it seems they no longer work with Daz3D studio 4,15. As i mostly export to Blender, I haven't rendered in a long time so i don't know when they stopped working. When i render in Iray only the CPU is used. What can i do to get them back to work?
Thanks in advance.
Same case here. Fortunately I found a 4.12 backup and I stil can render with that version.
I think the 770 is Kepler? NVIDIA's current Optix version s Maxwell or later architecture I think (someone correct me if I'm wrong).
https://www.daz3d.com/forums/discussion/comment/6200861/#Comment_6200861
4.14.0.8 (November 10, 2020)
I'm guessing maybe your GTX 770's with 2GB of VRAM ran out of VRAM due to the scene requirements maybe? You can check the D|S log file (Help/Troubleshooting/View Log File) and see if it mentions anything like the GPU's failing and it fell back to the CPU. And you can check the D|S usage of the GPU VRAM in Task Manager if you're on W10.
The video cards are 4gb each. I did a short render and the log doesn't mention anything about the GPU's at all. (Log file attached)
Unfortunately, i don't have a backup. Any idea where i could download the 4.12 version?
You sure your GPU's are selected for rendering? The log doesn't even mention them. It does have some "unsupported function" calls for the hair, but not sure whether that's important. Maybe that's related to the unsupported Kepler? But I'm not sure if unsupported Kepler means it will flat out not work, or work with limitations, or still work fine.
Kepler cards are history with Iray.
So it seems. I asked support for the 4.12 version. Hope that will help.
The log you posted didn't include the information written during starting up DS, this is what is found in the log with a supported GPU
2021-03-14 09:54:34.934 Iray [INFO] - IRAY:RENDER :: 1.1 IRAY rend info : NVIDIA display driver version: 456.38
2021-03-14 09:54:34.935 Iray [INFO] - IRAY:RENDER :: 1.1 IRAY rend info : Your NVIDIA driver supports CUDA version up to 11.1; iray requires CUDA version 11.0; all is good.
I checked the log after startup and it says the GPU's aren't supported.
2021-03-21 16:02:29.441 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(359): Iray [WARNING] - IRAY:RENDER :: 1.1 IRAY rend warn : GPU 1 (GeForce GTX 770) with CUDA compute capability 3.0 is unsupported by this version of iray photoreal for technical reasons (compute capability 5.0 or higher is required).
2021-03-21 16:02:29.442 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(359): Iray [WARNING] - IRAY:RENDER :: 1.1 IRAY rend warn : GPU 2 (GeForce GTX 770) with CUDA compute capability 3.0 is unsupported by this version of iray photoreal for technical reasons (compute capability 5.0 or higher is required).
2021-03-21 16:02:29.442 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(359): Iray [WARNING] - IRAY:RENDER :: 1.1 IRAY rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
I asked support for an older version (4.12) and hope that will get me back to rendering with the GPU's.
Thanks for your help.
