Adding to Cart…
Skimpy outfit - Andromeda
I haven't uploaded a good render of Sexy Maid Outfit for Genesis 2 Female(s).
Playing with lights and shadows. I like how the scene is dark.
Memory usage: ~ 575 MB.
Lana is on the left and Gwen is on the right.
Thank you for not complaining about how inappropriate my renders are.
Techno Tabby and Helena skin on Victoria 4
Compared to some stuff popping up in my renders, this is not all that inappropriate, really ;)
Hi mori_mann, thanks for looking. Here is classic deco in bad light. Opps.
Memory usage: 1.8 GB.
Take a look at this render while I try to fix my current issue with Victoria 4. I did not add any walls because I am using 32 bit Daz Studio.
The shorts of Victoria's pirate outfit are cut low.
Memory use: ~1 GB
Fantasy Assasin's Creed
Playing with an old scene. This scene would be more dramatic if I adjusted the lighting or changed the background. :D Yes, Victoria's armor is supposed to be white. I'll apply a shader to it later.
The background is a bit too dark.
Skimpy outfits by Val3dart will follow
Arkangel
Memory usage: ~850 MB
I should change the name of the thread to my skimpy outfit test thread. lol
Arkangel uses less memory than I expected. It uses 685 MB. Now to find out how much memory Luke uses.
What is that black rounded, semi-transparent shadow on the render where you mention her outfit is white? On the left side.
I like the action in these, you can really feel the energy.
After I adjusted the lights, the shadow still exists. The light isn't fully illuminating the curved surface of the background mesh and texture.
Bed time. I forgot to load the teddy bear.
Fun with 64 bit Daz Studio. Yes, I know the scene needs work.
Memory usage: 1.1 GB. 1.4 GB while rendering.
Catgirl taking a shower. I'll try to fix the lighting.
Cat lady and Luke switch places. I want the spray tool. Too bad I missed Nerd3D's sale.
Ah, I see! I haven't had that happen...yet. I'm sure I will! :)
Psycchotic. My attempt to recreate the shower scene from Alfred Hitchcock's movie Psycho. Its a start. I forgot to apply the texture to fantasy assassin.
Image removed, please refer to http://www.daz3d.com/forums/discussion/3279_98/ Thanks for your understanding :)
I remembered that I have Major Cache For Michael 4. I tried to render a better version but 32 bit Daz Studio ran out of memory. Looks like I will need to re-create the scene on the Windows 7 computer.
Here is another scene that I need to setup on the 64 bit Windows computer. I didn't even load a background yet. Wilde Rhoads for Genesis.
I think the guns have a lot of polygons? I'll try loading the clothes without the guns and holster.
I finally made a decent render. Opps... you can't see her face. Let me fix that.
Memory usage: ~710 the last time I checked
Edit: here is the new version.
64 bit version
Daz Studio uses 750 MB of RAM when the scene is loaded but when Daz Studio is idle.
Daz Studio uses 1024 MB of memory when it was rendering the image.
Elven Nymph. I'm too sleepy to create a more fancy render on the fast computer.
reminder for me to work on some old, romantic renders
quick test render of Stephanie Petite 3. I thought have already created this scene. Apparently, I did not. Therefore, I had to create this scene. I'll play with the lights some more.
Dawn and Stephanie Petite. I would have rendered the scene in Lux render but I ran out of time. At least I saved the scene file so that I can setup the scene using Luxus or Reality.
quick test render in Luxus
Wachiwi. I forgot to load her hair. I loaded Hawthorn hair instead.
GIS Pro again. I know, the lighting needs work.
