male Anatomical Elements Issue
Hopefully no one finds this salacious and can help me reslove this issue.  Having an issue with the male anatomy.  It does not seem to be attaching correctly which is creating a wierd discoloraction.  In this example I am using the Marcus skins but it has been a consiant issue with otther mats I have tried. Also added an example of what it looked like prior to adding the mats.
  • Richard HaseltineRichard Haseltine Posts: 109,616
    These are the daz anatomical eelements, with the same materials, or at least both Iray/both 3Delight from the same character set? The join with the rest of the body is not there the penis meets the torso but roughly the V of the groin itself, so the discontinuity does seem to be at the mesh boundary (unless it isn't fitting/grafting at all - do you have a hole when you hide the Anatomical Elements?)
