Help about light for render
Hello everyone. I'm new user for Daz Studio, therefore i need help. I'm preparing a scene for evening hours, but I couldn't because the window was white. Whatever I do, I couldn't fix the white thing reflection of window. I've searched a lot of information about that but couldn't find any solution. Even though I changed the time of scene from day to night in "environment" tab, the windows still looked white. I just want to know how to fix this situation. So, I want the window to seems black for the evening.
I, a new user will be happy and be grateful for any helps.
  • AnimAnim Posts: 241
    edited March 2021
    It can be that your evironment is set to off. In that case a solid background color gets rendered.
    You can activate the dome drawing in the environment tab.
    1277 x 813 - 150K
    915 x 750 - 111K
    Post edited by Anim on
    edited March 2021
    ... or maybe your environment is set to "scene only". In that case the emvironment does not get rendered and does not contribute to the lighting.
    You want "Done and Scene" in your case.
    1095 x 892 - 182K
    973 x 597 - 105K
  • aliilhanaliilhan Posts: 9
    You have my gratitude, thank you so much for helping me.
    edited March 2021
    You are welcome.
    There is one more setting that can be relevant:
    Beside the dome in the render settings environment there is another panel also called Environment (it is a bit confusing in DS to have two sets of settings which are called the same). In case it is not visible in your interface you can activate it via [Window] -> [Panes].
    If that Environment is set to Backdrop it will replace the dome drawing. This backdrop can be a solid color or a texture. If the Visible in Render switch is on then this backdrop will be visible and not the one from the environment in the render settings. But you still get the lighting from the render environment settings.
    725 x 437 - 48K
    494 x 399 - 35K
    668 x 708 - 69K
    Anim said:
    You are welcome.
    You are my hero!
    There are two questions in my mind about that environment and backdrop settings:
    First one, which resolution should I choose for outdoor shooting? I want to use in backdrop by the way.
    Second one, backdrop photo is rotating along with the camera angle if i tried to use it. In fact, I do not want to rotate with camera angle, do you know how to stop rotating it?
    Thanks in advance!
    edited March 2021
    Welcome to the world of 3d rendering. It is a Hydra - once one question got answered at least two new ones grow up.
    Backdrop and resolution
    There are two aspects to consider:
    • resolution of your render
    • aspect ratio of your render
    Resolution:
    We like to have image files with resolutions that deliver sufficent detail in the final render result. In case of the backdrop we need to know that the image assigned to it gets squished to the render resolution. E.g. if the render is set 1024 x 1024 pixel then the loaded image gets adjusted to that resolution even if its original resolution is different.
    The first render example is 1024x1024 pixel and the image in the backdrop is 256x256 pixel. Issue is that the image does not provide enough detail because of the low resolution - It looks blocky.
    For the second render an image with 1024x1024 pixel was used which is the better decision in this case.
    I dare to say that in case of backdrop usage the image should closely match the render resolution. But if the backdrop image is anyway a blurred one e.g. like an out of focus blurred backgound picture it might work with a much lower resolution.
    Aspect ratio of your render
    This one is relatet to resolution because the x and y resolution define the aspect rato. If we load an 1:1 image but have a 2:1 render then the image gets streched to fit the 2:1 ratio.
    Render 1024x512 but image is 1024x1024
    Render and image are 1024x512
    1024 x 1024 - 463K
    1024 x 1024 - 459K
    1024 x 512 - 264K
    1024 x 512 - 632K
    The background images I made for the test.
    256 x 256 - 4K
    1024 x 1024 - 19K
    1024 x 512 - 11K
    edited March 2021
    Regarding the backdrop rotation. There is no way to stop it from doing this as far as I know.
    That's the reason the backdrop can be of limited use sometimes. But we can use a simple plane and put the image on that one. This plane can then be handled like any other element in the scene.
    [Create] -> [New Primitive...]
    Scaling direction and rotation depends on what Primary Axis you used when creating the plane.
    542 x 335 - 25K
    606 x 378 - 19K
    657 x 642 - 80K
    754 x 303 - 29K
    1218 x 305 - 53K
    1124 x 750 - 70K
    Limitation of the image plane:
    It blocks light. An image plane is normally like a solid wall. Light from the environment or other sources does not go through (the backdrop does not have this limitation).
    But you can be tricky and make the plane a light itself. Any geometry in DS can be a light source. Because the plane is geometry this can help sometimes.
    500 x 523 - 32K
    500 x 426 - 29K
    522 x 480 - 53K
    500 x 410 - 24K
    Anim, best wishes for you, you are a noble hero!
    Thank you so much!
    Thanks and happy rendering.
  • SevrinSevrin Posts: 6,314
    I can sympathize.  That set is a PITA to light.  Ideally, you want to light indoor spaces realistically with "functional" lighting, i.e. window light and light from lamps, candles, etc.  With the lights in this place, I don't know how anyone gets any work done.
    edited March 2021
    Like @Sevrin wrote - I just quickly dropped a few candles into the scene and mixed environment, imageplane and spotlight plus a few adjustments in post.
    I think in the end it is about understanding the basics and then mixing everything together.
    Not: The render contains objects of different sets.
    • The most glaring issue: The main set lacks a detailed window. There is a metal grid normally but I didn't like the look. So I just left the window as a big empty opening.
    • The perspective of the background image doesn't really fit the scene, but I left it for this example render.
    • I ignored the shader on the left candelabra. Normally I would do something to get rid of the pure black look. I also ignored the flames. The PA created them as single planes which causes shadowing when they are not directly facing the camera. That's the reason why two of the candles have those darkened areas at the top and some of the small ones show thin flames.
    • I don't like the design of the table on the right. I looks cheep compared to the tub.
    • and so on
    As I wrote in the other post. Once one detail got solved others kreep up smiley
    1000 x 938 - 221K
    800 x 750 - 146K
