Daz To Blender Bridge - morph failing
I follow a youtube guide.
And still when i use the morph tool in daz.
The morphing only goes from Big to Small.
If you zoom to the small model you see the change.
1. I export the Genesis8 (basic) via the Daz to blender.
2. Go to blender and import Genesis8 via the addon
3. Make the change to my model (making the model pregnant) Using sculpt to change her stomach.
4. See the morph in the shape keys
5. Export the new model via. the addon key "to daz morph"
6. Go to Daz Make sure i am on the model.
7 Use Edit->Object->Morph Loader Pro
Option i pick
from: Daz Studio (like the use in video, tried other aswell. And get other mistake. Like morphing from standing to laying down with the change.)
Choice the model made via the export
Pick the reverse Deformation (also tried without.. same result)
And when i move the slide it just go from big to small.
Not morphing the stomach as it should and video show.
So how do i fix this?
@janrchr_044d7a7b61 Did you ever find your fix? I'm having the same problem.
