Ballet outfit and shoes in Ballet poses new release?
Kharma
Does anyone know where this ballet outfit can be purchased?
Kharma
Hello Kharma,
The tutu, toeshoes (and leotard, in popups) are V4 clothing, they're from the Art of Dance outfit by Littlefox (I didn't list non-Daz items in credits), you can find it on rdna.
The toeshoes and leotard do fit very well on G2F, I've only had troubles with the tutu (used the tutu part only, parented to her hip, otherwise it would break with every leg movement if conformed). I've used the top of an outfit called El Cisne (by fabiana, renderosity), too, on the main picture.
Hope that helps :)
Sickleyeild's Clara's Dream is a ballet outfit for Genesis (I think G1). It was on Rendo. There may be another, but I'm not placing it.
Thanks JOdel, I will check it out :)
There's also Diane's Giselle 6 Ballerina Poses & En Pointe Shoes as well. :)
Thanks, I do have that one , but would like to know where that leotard came from also :)
Most of the Littlefox stuff autofits very well. The skirts may need to be parented rather than conformed. (Note: I've even autofit and parented her old A3 ballet set and it worked very nicely, at least on G1. I stuck with the V4 shoes though, since they are rather better.)
Thanks, I do have that one , but would like to know where that leotard came from also :)Me to, lol.
Been fussing with skirts, and unless it has many handles (Even for a tutu), it just won't work for dancing, motion, and various poses. And adding the extra control surfaces to the mesh is not easy from what I gather from reading every thing I can find on the matter.
Some other posibilities, that would be EPIC.
http://shop.justforkix.com/dance-dresses/
These are NOT for CG.
(EDIT)
Especially for G2F and G2M.
Silly question, tho after the A4 skirt experience (Fw Eve 1size doesn't "fit all".), I must ask as an offshoot question.
"Giselle 6 Ballerina Poses & En Pointe Shoes"
http://www.daz3d.com/giselle-ballerina-poses-en-pointe-shoes
Do the shews work on G2F without Giselle 6, or are they explicitly shaped for Giselle 6? Will I be plagued with poke-threw issues without Giselle 6?
Looking at the design of the seam, I'm instantly reminded of something like Xena's Wicked Beachwear.
As for the shoes, There shouldn't be any noticeable issues considering that Genesis has auto-follow technology, so you should be fine.
If it helps, Clara's Dream Ballet transfers very well to Genesis 2, shoes and all.
Looking at the design of the seam, I'm instantly reminded of something like Xena's Wicked Beachwear. Except there are gaping holes in that swimsuit, it is a thought if they can be filled somehow.
If it helps, Clara's Dream Ballet transfers very well to Genesis 2, shoes and all. I like the patron in those outfits, nice renders.
(EDIT)
Clara's Dream Ballet by SickleYield
Rendo, I just came from there, face palm.
I have a free ballet outfit for genesis over at ShareCG which might fit G2F.
http://www.sharecg.com/v/65707/browse/21/DAZ-Studio/Genesis-Ballet-Outfit-Part-1
As for the auto-flow (Smoothing, collision, whatever) bit, I seam to have the nasty luck of stumbling onto stuff that dose not work. One generation jump seams to be ok most of the time, two or more tends to be problematic (constant adjustments for different camera angles).
Thank you whomever made that Generation # shapes for G2F/G2M, it has made lots of stuff better. V4 stuff works on G2F figures most of the time now. (I don't have the others yet).
[sarcastically] And custom fit from one generation to a different generation custom figure (A4 to V4 to G1 to G2F to Olympia6), forget it, there is going to be something wrong somewhere, Auto-fit gets all confused and stuff and starts putting things anywhere it can, lol. Hair at the shoulders, shoes in the knees, shirts threw the ankles, etc. lol
Tell me about it! I was recently inquiring about how to transfer Gen 3 hair to G1/G2 and... Well... Let's just say the situation got rather hairy... :-) *Shot*
But in all seriousness, you should try asking Kattey about it over in the Transferring G1 To G2 Thread. She really knows how to use the transfer Utility tool. :)
