I Need a Baby Wrapped in a Blanket
FauvistFauvist Posts: 2,224
Just like all those news photos of Princess Diana and the other British royals who step out of the hospital holding their new born infant in their arms.  The baby is wrapped in a little blanket or other fabric, so the most you can see of the baby is a tiny bit of it's face.  If this doesn't exist as 3D content, I need some way to fake it.
https://newsdio.com/here-is-what-prince-harry-and-meghan-markle-will-be-calling-their-first-baby/976/
  • SBibbSBibb Posts: 600
    Not sure where you might find a baby blanket or swaddle, but if your setup can handle dForce, you might be able to make a simple plane primitive for a blanket, then add dForce to it to drape the "blanket" over the baby.
  • SeraSera Posts: 1,675
    I would love to have a baby in swaddling, as well as a newborn for G8 or G8.1. I hope someone makes one.
  • FSMCDesignsFSMCDesigns Posts: 12,846
    maybe this one https://www.turbosquid.com/3d-models/baby-3d-model-1434301
    There are a ton iof babies and baby stuff on the normal 3d stores, but surprisingly not many wrapped up.
  • IceScribeIceScribe Posts: 694
    Here's a swaddle I used : Babywrap by Ramnimus/Cage/ShareGC. Old but could be modified. Baby Wrap - Poser - ShareCG
  • Griffin AvidGriffin Avid Posts: 3,822
    I just solved this issue two days ago. Believe it or not, I took a sandwich wrap- food prop and textured it with one of those kiddie room shaders and scaled it up to size and inserted the baby into the wrap.
    My first idea was a camping bag or rolled up towel, but when I searched 'wrap' the food prop showed up first and it had the right shape.
    There's a bed roll that comes with a western camping set too.
    Griffin Avid said:
    I just solved this issue two days ago. Believe it or not, I took a sandwich wrap- food prop* and textured it with one of those kiddie room shaders and scaled it up to size and inserted the baby into the wrap.
    What product was the sandwich wrap prop from?
    *Emphasis is mine.
  • scorpioscorpio Posts: 8,533
    This might work as well
    https://www.daz3d.com/organix-cocoon
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,259
    mmm wonder if I could wrap a posed baby obj in Zbrush with the cloth brush
  • tsaristtsarist Posts: 1,638
    Well, as long as there are no giants about, there should be no problem.
    Fi fi fo fum
