Daz Studio 4.15 Pro blank upon opening
davehal9000davehal9000 Posts: 19
edited March 2021 in Daz Studio Discussion
A warning; I'm not very adept at using Daz.  I no doubt did something to cause the problem and there's an easy, obvious to everyone else fix.
Opened up Daz Studio 4.15 Pro earlier today and there wasn't anything open on the screen.  The program was open but none of the menus, display. anything normally there when I've opened Daz in the past.  There's an "Advanced" tab and that's it.  When I try to open any saved files, scenes, etc, nothing ever shows up.  Any suggesions?  Thanks in advance!
Windows 10
Post edited by davehal9000 on
  • Lee MoonLee Moon Posts: 927
    Maybe try going to the menu item Window -> Workspace -> Select Layout...  and then select the layout that you had before?
    I'm truly not sure if this will work for you or not.
    Lee
  • That did it.  Thank you very much!
    I don't use Daz often enough to be any good at it but can always find a way to mess it up!
