Is it possible to have one adjustment effect multiple things at once?
SchaakaSchaaka Posts: 164
In the picture I use as an example. Lets say i want to add a +10 to the X translate axis for every child in this string (is that the correct term in daz?), can I do that? Assume there isnt a morph or parameter that does what i am looking for.
If i select them all and adj +10 only the first one will get the modifier and id have to go to each one individually and add 10. As you know that gets tedious.
Thanks for any answers!
  • GordigGordig Posts: 10,805
    What you're looking for is an ERC freeze.
  • lilweeplilweep Posts: 2,873
    if youre not talking about ERC Freeze - which allows you to set master/slave relationships - you might be looking for a more simple ad hoc solution
    See multiselection at around 5min mark
