Knit: St. Patrick's Day
I didn't realise that this shader is ovr 1 gig. Why so big?
  • LeanaLeana Posts: 13,010
    40 material presets using several 4096*4096 maps each. That takes space.
  • SevrinSevrin Posts: 6,314
    You can always just download and reduce the images to whatever.  They're nice, though.
  • MimicMollyMimicMolly Posts: 2,352
    Some Iray shaders are just like that. At least 4k × 4k squares for Diffuse, Translucency, Bump, Normal, maybe Opacity, sometimes Metalicity (?), and it's not always in .jpg, because .png and .tiff are even bigger, "less lossy" formats. Then multiply it by 40 or however many unique patterns.
  • jd641jd641 Posts: 462
    Anyone else not able to download the DAZ Connect Offline Package. I'm getting
    code "not_found"
    message "File with such name does not exist."
    status
    404
    I still get that with Honni 8's Offline Package too even after three months with an open ticket for the issue and getting told on the forums that my issue would be looked into.
  • Carola OCarola O Posts: 3,862
    I can't install via Daz Connect at all, not even getting to see the product in the Available tab. However whenever I update metada I get 1 that fails, I'm guessing it is these shaders since it started after I checked out with them
  • Richard HaseltineRichard Haseltine Posts: 109,633
    I'm told that this has been reported up the chain.
    Thank you Richard :) I wait a little bit longer with a ticket
    Just wanted to check in to hear if you @Richard or anyone else has heard anything more about this? I still don't have these shaders available to install, and I still get the Metadata update fail info.
    339 x 53 - 8K
    I haven't heard anything, no. Sorry.
    Thanks, I wait a little longer and than make a ticket if needed :)
  • ecks201ecks201 Posts: 489
    4 Month bump...
    Any news on a fix for the above problems?
  • Daz Jack TomalinDaz Jack Tomalin Posts: 13,922
    Is there a ticket at all that can be escalated?
    I raised the metadata problem on 365673. It's a missing file which could be part of the problems above.
    The missing file is https://cdn.daz3d.com/file/dazcdn/p/11/80611/meta/80611_a1e45f_data.json
