mcjHelpMeAssembleThisMachine - V3 - build accurate models in Studio
mCasualmCasual Posts: 4,607
edited March 2021 in Freebies
for example people that spend their whole Sunday trying to figure how to build version 2 of their CNC router
https://sites.google.com/site/mcasualsdazscripts9/mcjhelpmeassemblethismachine
the set of ccordinates is now complete : origin, min center max
Post edited by mCasual on
  • richardandtracyrichardandtracy Posts: 7,412
    edited March 2021
    Attachment Mates in DS?!? Whatever next?
    That will prove useful. Really useful. Makes it possible to model parts without needing to do the assembly in the modelling package.
    Coincident mates for selected surfaces rather than bodies could be useful too, but not even sure what you'd have to do to select flat faces in DS.
    Thank you.
    Regards,
    Richard.
    Post edited by richardandtracy on
  • Richard HaseltineRichard Haseltine Posts: 109,279
    Added to the index, thank you (in the Creation post) but I'm not sure my description is right.
  • Eustace ScrubbEustace Scrubb Posts: 2,730
    Might I suggest also cen[Axis]min/max[Axis] options?  In fact, it might clean up both code and UI to reference both pieces by dropdowns:
    Align Part A [Min/Center/Max] [X/Y/Z] with Part B [Min/Center/Max] [X/Y/Z] allows for 81 permutations, using only four buttons, rather than 15 permutations with a separate button for each, as above.
  • mCasualmCasual Posts: 4,607
    edited March 2021
    Major Update
    Version 2 lets you resize and reposition an object with precision
    and when 2 objects are selected you can now specify the distance between the 2 objects min/cen/max
    instead of a distance of zero ( which  was the case in version 1 )
    1080 x 1080 - 442K
    874 x 1014 - 94K
    793 x 1065 - 82K
    Post edited by Chohole on
  • Silver DolphinSilver Dolphin Posts: 1,640
    Nice. Thank you
  • That looks like a really useful update. Thank you.
    Regards,
    Richard
    edited March 2021
    another update: V3
    now you can do measurements and moves base on the source and target object's Origin, Minimum, Center, Maximum
    2128 x 1580 - 460K
