Genesis 8 Morphs doesn't show up.
I've purchased and download Genesis 8 Morph(42083) but I can't use it. I downloaded it through Daz Central and it doesn't show a file and when I click open from daz central. It sais that Resouce Error Could not find the 42083 product.
    Morphs are not poses and therefore can not be found on Posing-tab, use the Properties-tab instead.
  • neungvanderwaalsneungvanderwaals Posts: 1
    edited March 2021
    I'm apprciated your answer but I'm not sure if that is the problem that I have.
    I can't add the morph to begin with. It's not that I look at the wrong tab when that tab doesn't exists. It doesn't show up in my library at all. You can see on the left side (from the screenshot) that the Genesis Morph folder have nothing on it. If you look at another image, you will see that even daz central can't find the resources and I've reinstalled it multiple times.
    Post edited by neungvanderwaals on
  • Richard HaseltineRichard Haseltine Posts: 109,294
    The morphs don't have "user-facing" files, for the most part - they are added to the figure when you load it and will appear in the Parameters pane and in the Editor tab of the Shaping pane.
  • In your content library, if you go to Daz Studio Formats (way up top) then People - Genesis 8 Male - Shapes. Can you find the morph there? Can you apply it?
    Like Richard said, the morphs are automatically loaded when you load the figure, there are no files to load in Content Library.
    Select the base figure in Scene tab and go to Parameters tab or Shaping tab and you can find dials for those morphs. The dials are used to apply the morphs.
