Genesis 8 Male head morphs error
Hi. This is sort of a strange problem - but all the sudden I have a number of genesis 8 male assets whose heads aren't morphing correctly. Some are totally fine - while others seem to be distorted. Loading these characters doesn't create any entries in the log file. I have tried uninstalling/reinstalling Daz3d, genesis 8 male, genesis 8 essential files and each of the affected characters. So far nothing has had any impact. I've attached photos of a couple examples. The first is Jeremy by SF Design, then Rocco by Mar3D and then Toon Generation 4 male. Any ideas?
What does it show in the parameters tab if you select "currently used' in the top left?
Please put the Viewport in Smooth Shaded mode if you want to shjow a nude figure - in this case you could also have zoomed in to show only the head and shoulders.
Whoops. Reposting a couple shots zoomed in with Currently Used selected.
Maybe you can try:
Load G8M Base Male, Parameters top right, Zero Figure then Memorize Figure
Then top left menu in DS File -> Save As -> Support Asset -> Save Modified Assets
This will essentially force all your sliders to zero and saving it in this way is kind of like a factory reset for how G8M loads in. (you wont lose any sliders, they're just all zeroed)
Then reload a G8M and see if the problem persists.
Hausfrau - you sir and brilliant. Thanks! There was basically a morph from another asset that was hiding.
Hey.... call me Mom. ^_^
(im on a roll)
