Removing clothing from a saved figure.
Hi, I can't locate any discussions about removing the clothing from a previously saved figure. I'm not sure how to start over as I used a special face for this figure and you only get 3 saves. How do you get the base garments off so you can change their outfits? I can't find a removal feature and they won't simply hide.
I'd truly appreciate and tips.
Thank you in advance!
Are these separate models? Then you should be able to select them (in the Scene pane or by right-click - a single left-click will select the bone of the figure the clothes are fitted to, since that is what is needed for posing) and delete them in the usual way (delete key or from the Edit menu)..
You must be using the trial version of Face Transfer. The 3 saves refers to actual face saves. You can only have 3 seperate faces saved in this version. You can save each character out as a scene or sub scene as many times as you like. Just load a clothed character in, delete the unwanted clothing, redress it and save out under a new name as a scene or sub scene.
