cms problem. need help !
hi i have cms problem.
today update beta daz .after that cms error appear.   (before update ,i use beta daz well ,no promblem)
uninstall beta daz version 4.15.0.13  and install normal daz , but still appear cms error.
i use win 10(64) kasperskey.           ..i stop kasperskey ..but cms error still appear.
postgres.exe not running background process and service
plz help.!
  • PostgreSQL is installed? Which version, beta or general release/32 or 64 bit?
  • yes install.
    PostgreSQL CMS (Win 64-bit) Public Build +Beta+
  • now use DAZ Studio 4.15 (Win 64-bit) Public Build +BETA+
  • Word of the wise: don't mess with beta versions if you can't handle the aftermath, there is no guarantee that things will be working properly.
    Having said that... you need to make sure that DS is pointed to the right directly for the cms. If those changes do not retain as you said then I think you got bigger problems, problems beyond DS. Because then it seems as if there's a problem with your system somewhere which prevents DS from saving its configuration.
  • OK, the next possible issue is write permissions to the ContentCluster folder or the folder in which the configuration is stored -
    %AppData%/daz 3d/cms/
  • %AppData%/daz 3d/cms/                 ----permission is administrators,system,me  ..not problem.
  • Richard HaseltineRichard Haseltine Posts: 108,603
    edited February 2021
    You could try editing the port number in cmscfg.json there and see if it sticks.
  • i edit cmscfg.json and change open port.    but  useless..
    i wonder why i can not change cms cluster directory ?
    it alway reset empty.
  • That does sound as if there is an issue of some kind for DS in accessing the file/folder.
