Shapes appearing when using Light Geometries
When I try to change the light geometry for my point light, there is this weird shape that comes up on the screen. Once every so often I'm able to make a render without seeing that, but I'd like to know what it is that I'm doing that could be causing that. I tried looking around in the forums, but it doesn't seem that that many people are having this issue.
  • That's the light, turn off render emitter to hide it from direct view (it will still show in relfections and viewed through other objects). Alternatively, use a ghost light - create a plane, apply the emissive shader preset, and set the light as you want in the surface pane then lower the Cutout Oapcity to almost, but not quite, 0.
  • Gemini QueenGemini Queen Posts: 263
    edited February 2021
    It's gonna sound silly, but where is the render emitter setting? I looked in Render Settings, and couldn't find it. I also look in the surfaces tab, but didn't see it there either. I might be overlooking it.
    Edit - Lo and behold, I was overlooking it. Thanks!
    Post edited by Gemini Queen on
