Problem with Steampunk Airship Cabin
I tried rendering one of the control Panels in Steampunk Airship Cabin and this is what I got. There are similar problems with most of the displays and dials in this product. Due to the extensive use of instances in this product, I can't even find the individual objects to attempt to correct them.
  • Looks like you've got the wrong render engine selected.
    Under render settings, make sure 'Engine' is set to iray.
    If you intend to render in 3delight or openGL, you'll need to rework the material/shaders to be compliant with those render engines.
    The first render is iray, the second 3delight.
    1000 x 1000 - 2M
    1000 x 1000 - 852K
  • pwiecekpwiecek Posts: 1,598
    edited February 2021
    No, its the same in Iray. In fact, if you really look at your render, the guages are just as far off. You just can't see it because the render is so dark.
    Here is an actual screen capture of what the panel looks like
    746 x 531 - 62K
    Post edited by pwiecek on
    I have tried to submit a ticket, but I'm not sure it went through. Is there any immediate indication of a succesful ticket submission?
    You should get a Thank You For Contacting Daz 3D email.  If you didn't, had you clicked the Sign In button at top-right of the ZenDesk page? It seems to need that extra prompt to pick up your Daz details (and you won't then have to use a captcha).
    I'm pretty sure I messed something up, I just didn't want to spam them.
    LATER
    No email, but I can see it in the system now.
    THanks again.
