Changing the manipulator position in relation to its object...
I recently imported an object into D4 Pro. The object imported fine, but the manipulator was very far away from the object itself, making it a little hard to work with. Is there a way to change the manipulator's position in relationship to its object without changing the object?
Thanks.
There is a Script by DeltaX15 called Move Origin which can do that. It works in DS4P too. See the link below for more info.
http://www.daz3d.com/forums/discussion/3600/
Thanks Jimmy,
I found the script and loaded it into DS, but I can't get it to run. The Scripts menu doesn't do anything when I click on it. I have DS4 Pro so I thought I would be able to run scripts. As usual, Daz's documentation is very sparse, and I'm having to rely on the community to help me with all of the little things. You guys are great!
Thanks again.
Hmm... Which version of DS4 are your running? Also, do you have the object selected when you use the script?
Check this thread, too. There are some additional tips.
http://www.daz3d.com/forums/discussion/4721/
