Body Warmer, Gilet, Winter Vest....?
Fungible UserFungible User Posts: 456
edited February 2021 in The Commons
Hello Dazzies...if anyone by chance knows the whereabouts of a body warmer, gilet, or winter vest similar to the below, could you please share its location. I feel as if I have seen one somewhere. Not sure at Daz or elsewhere. Preferably for men, but a female version would also work.
Post edited by Fungible User on
  • HavosHavos Posts: 5,623
    Any type of winter/warm clothing is slim pickings at this, and other DAZ/Poser stores, but the closest thing I can find is this:
    https://www.daz3d.com/urban-metro-outfit-for-genesis-2-male-s
    It should autofit to G3M/G8M without issues. Main snag of this one is the zip is partially open, so you either need to make a morph, or use something like Mesh Grabber to attempt to close it.
    Another (very old) option is this.
    https://poserworld.com/hiking-set-for-daz-victoria-4
    At least it comes completely closed, and has morphs to open it. You should be able to get it onto males via autofit to Genesis, and then to G2M/G3M or G8M as desired. I have the set, so I can show you what it looks like on G8M it you want.
    The only other option is to use a full winter coat, of which there are a handful, and either use a transparency to remove the sleeves, or hack off the sleeves using some mesh editor like Hexagon.
    Post edited by Havos on
  • There's also this: https://www.daz3d.com/urban-survivors-hd-for-genesis-2-female-s-and-male-s, but it's open so i don't know if that's a deal breaker.
    Thanks very much Havos, gonna have a play around with these suggestions.
  • Fungible UserFungible User Posts: 456
    Hey zombietaggerung, thanks very much. This is great. Gonna convert it and see how it looks
