Content Library File Path
PinzelmeisterPinzelmeister Posts: 114
edited July 2014 in Daz Studio Discussion
I just added a hard drive and moved all my DAZ content (from C: to G:). That changed the file paths of course . . . i had very little trouble fixing that using Content Library/Edit Preferences etc. So all my files open properly now, but my content folders still show the old file path (see attachments). I.e. my content is not showing up properly. Could someone give me a tip on fixing this?
Post edited by Pinzelmeister on
  • BejaymacBejaymac Posts: 1,967
    Your either using the Categories part of the Content Library which is a poor quality database, or the thick as **** Smart Content which uses metadata, both of which will need rebuilt in some form, I don't waste my time with either of them so someone else will have to explain how to do that.
    Go to the Content Library pane drop-down menu.
    Select 'Content DB Maintenance' and click on 'Re-import Metadata'.
    See if that works.
  • PinzelmeisterPinzelmeister Posts: 114
    Re-import Metadata worked for some of the content. Most of my stuff still looks like this however (attachment). The old path needs to be changed to the new path. I could do this manually for each file I suppose; actually I couldn't since there are way too many that need fixing. Is there a way to change all of them at once?
    893 x 373 - 131K
  • Richard HaseltineRichard Haseltine Posts: 109,300
    If you choose the edit Base paths option you should be able to update all content at once.
