Converted Clothing Does Not Fit on Figure
Epic82Epic82 Posts: 131
I purchased the Clothing Converter from Genesis 8 Female to Genesis 3 Female and the RSSY Clothing Converter from Genesis 2 Female to Genesis 3 Female a long time ago, but I've only recently started to use these two utilities. Earlier this morning, I converted Jungle Girl for Genesis 2 Female(s) with the RSSY Clothing Converter from Genesis 2 Female to Genesis 3 Female, and I had no problems fitting the converted clothing to a few Genesis 3 Female figures. But now, for whatever reason, the converted clothing doesn't fit to Genesis 3 Female anymore. I've attached two screenshots of this error below (I've applied a geoshell to Genesis 3 Female so there is no nudity in this post. I hope that doesn't confuse anyone). Has anyone else had this problem and found a solution to it? If someone replies after I leave for work, I'll respond later today or tomorrow.
Post edited by Epic82 on
  • After you converted the clothing, did you save them? {with different names to different folders so that they do not overwrite the original files}
  • Epic82Epic82 Posts: 131
    Thank you for your reply, Catherine3678ab. Yes, I believe I did. Below is a screenshot of the files I've converted and saved so far with the RSSY Clothing Converter from Genesis 2 Female to Genesis 3 Female.
    517 x 370 - 122K
  • Well that's odd. The only thing that I could suggest would be to remove all the new files, maybe reinstall the original product, repeat all the conversion steps being careful to save to different folders [i.e. not using the original folders for the original product]. Check that everything seems to be working. Close D/S, reboot the computer, open D/S and see if the files are still working.
    If not, clear the scene, clear the log report, reload the items and see if the log report provides any helpful information.
    Maybe somebody else has some ideas to share.
  • Here's the product thread, this would be a good place to ask the question again so the PA sees it :-)
    https://www.daz3d.com/forums/discussion/316466/released-rssy-clothing-converter-from-genesis-2-female-to-genesis-3-female-commercial
    Thanks for the link.
