mcjTornare - DS 1,2,3,4+ Script to turn something ( usually an arm ) around an arbitrary axis, quick
mCasualmCasual Posts: 4,607
edited July 2014 in Freebies
before resuming my resuming work on mcjTeleblender 3
a quick script to animate turning motions
https://sites.google.com/site/mcasualsdazscripts4/mcjtornare
rotating around an axis that is not one of the three ( x y z ) axis
similar to mcjExoRotator http://www.daz3d.com/forums/discussion/35826/
Fig 3
well actually this was made mostly using
-mcjAutoLimb2014
-mcjHoldOn
-mcjMakeTarget
-mcjParent
-mcjKeepOrient
Post edited by mCasual on
  • atticanneatticanne Posts: 3,009
    Now, this will be neat! I'll be watching and waiting.
  • mCasualmCasual Posts: 4,607
    edited July 2014
    since there's already mcjExoRotator for complex animation tricks
    i'll stick with my original intent which is a simple script
    for cases where you just want to select 2 nodes, click a button and bam
    the rotation is done - well you must also specify the angle in degrees
    424 x 599 - 984K
    edited July 2014
    1 - select a target ( the tip of a screwdriver parented to an arm )
    2 - select a turning node ( the shoulder joint of that arm )
    3 - specify a spin angle ( 45 degrees )
    4 - Specify the keyframes to process ( current frame only )
    4 - click the 'do it button'
    done !
    fig 2 - a spin angle of 30 degrees was added to an exosting 15 frames animation in 1 click !
    Fig 3 - Testing in DS 4.6 and adding fearures
    fig 4 - the official logos ! collect all 2
    fig 5 - the test in DS 2.3 was interesting it shows cumulative effect of the rotation when you start with something that is not yet keyframed
    500 x 281 - 29K
    1914 x 978 - 483K
    1306 x 598 - 198K
    424 x 599 - 874K
    696 x 460 - 117K
    * * Ready ! * * Ready ! * * Ready ! * * Ready ! * * Ready ! * *
    427 x 592 - 61K
    edited July 2014
    New Improved ! and there's a Movie ! ( 1 minute and a half, lets say a short feature ) for mcjTornare
    Exciting action-packed ! with custom TTS-lipsync
    https://www.youtube.com/watch?v=_wHzuOrKBfg
    The new version of the script is at
    1280 x 720 - 428K
