rendering difference
13»
  • VicSVicS Posts: 1,273
    i guess the denoiser enable should not be on after all, her face also looks much better without it yes!! now i only need to set render time to infinity until all white dots are gone does anyone know where to do that? "i tried max time to zero and to 1,000,000 both ways the render is very fast"
    2551 x 1510 - 2M
  • that is the way I learned to tweak lights and render settings, you will be getting good than rest doing experiments and taking notes.
    keep experiment! laugh
    i put the image up again, looked like it wasnt up anymore
    2551 x 1510 - 2M
    yeah thanks for all the advice, the renders look better than did before by far, im playing wityh a combo of emmisive and hdri and headlamp (not just scene anymore)-still not near as good as i want such as the clarity of the image of woman in ocean
    BTW-if i dont use emmisives then it just doesnt do it for me, i know other people get by with just one light-sky dopme or hdri-i know i missing something-or a lot-sometimes i do the render with denoiser on-my render goes so fast it leaves much noise na di have no idea how to change the render time-so what i do is either with denoiser on or off just take a screen shot of rendered viewport for now until i can know how to set the timer on the actual render-this way i have t put all backgrounds in the scene but in the end it will probably make the image better to look at than adding a background image in  Gimp-(guess it just cost more money to buy all the props needed !)
    to me stuff is still washed out-some of the textures pick up good but
    2888 x 1764 - 4M
    1302 x 1698 - 4M
    edited March 2021
    If you leave "Max Samples" at 650, and "Rendering Quality" at 0.1, you will get fast renders that are not finished. Time is not the only parameter stopping too early, all three will have an effect.
    Edit, My settings are;
    "Max Time" = 36000
    "Max Samples" = 15000
    "Rendering Quality" = 1
    Post edited by PerttiA on
    "Max Time" = 36000
    did the settings on this
    the viewport keeps rendering so the noise is much less in the oj
    this is a completed render where the cancel button turned to close
    2952 x 1690 - 7M
  • TugpsxTugpsx Posts: 797
    edited March 2021
    Zilvergrafix said:
    I invite you to look Part 02 and Part 03 is a few hours to release.
    @Zilvergraifx What happened to all your great tutorials. I was enjoying them then they were gone. Have you moved them to Vimeo or something. Please share again.
    Post edited by Tugpsx on
  • ZilvergrafixZilvergrafix Posts: 1,385
    edited March 2021
    all my tutorial are now backed up on Odysee
    Now i'm working in Japan full time with a company, read my signature forum. laugh
    Post edited by Zilvergrafix on
    WoW! congratulations and thanks for the updated link to the tutorials.
